      Comand NTG2.5 Firmware update - https://www.mb-treff.de/forum/thread.php?id=7548
Geschrieben von Grozdanov am 11.02.2013, 15:05 Uhr:
Hello,
I bought the new Firmware update CD - A171 827 41 59 26 for NTG2.5 and now I want to know how to install it? Thank you very much!
Geschrieben von spookie am 11.02.2013, 15:57 Uhr:
Normally the Firmware CDs have the same partnumber at the beginning like the car you want to use them - a CLK for example 209. Please be sure you have the right one. If not a firmware update can kill your system.
Geschrieben von Grozdanov am 11.02.2013, 16:25 Uhr:
Yes, firmware version is correct for comand ntg 2.5, but I don't know how to install. In ntg1 press and hold buttons "1", "3" and "8" and on the display write "Insert CD Update" and works! But I don't know how is in ntg2.5
Geschrieben von Brovning am 11.02.2013, 18:08 Uhr:
Hello,
press and hold the following three buttons for 10 seconds:
Geschrieben von Grozdanov am 11.02.2013, 21:07 Uhr:
Hello,
And afer that in the diplay will write "Please insert CD" ?? Thank you very much!!!
Geschrieben von Grozdanov am 13.02.2013, 15:48 Uhr:
Hello,
When I entered in Engineering mode and SW update menu, the button "start" is not available. I want to change world region from US to EU because the radio (Comand NTG2.5) reads only even numbers. And for installing new navigation map Comand must be EU version not US. Is that possible?
Geschrieben von Brovning am 13.02.2013, 19:05 Uhr:
Original von Grozdanov:
As far as I know, changing the region is not possible. Only by changing the whole Comand 2.5...
Why is there no update button available. Could you please upload a picture?
Geschrieben von Grozdanov am 13.02.2013, 19:34 Uhr:
On the display had two buttons - "Start Update" and "Abort" and only "Abort" was available. Maybe because I tried EU firmware to Mercedes US version. I can't upload a picture because the car is not mine.
Geschrieben von Brovning am 15.02.2013, 10:25 Uhr:
For the firmware update you need the Telematik-Update DVD and a StarDiagnosis which is online. Alternatively there must be an installed Developer-Kit on the StarDiagnosis.
If you also bought the newest Navigation DVD and the DVD is not compatible with your firmware, then you get the firmware update for free at your Mercedes authorized workshop.
The following updates are incompatible:
- version 1.1 to 4.1 or higher
- version 2.0 to 5.0 or higher
The current version is 8.0.
Geschrieben von Grozdanov am 15.02.2013, 12:31 Uhr:
I have StarDiagnosis but not is online and I have Telematik-Update CD (not DVD) - A171 827 41 59 which I bought in Mercedes authorized workshop for 15E. I entered in engineering mode with buttons combination which you said me and when I tried to start update, the button "start" is not available.
How to know whether I have installed Developer-Kit on the StarDiagnosis and which menus in StarDiagnosis are for Comand firmware update?
